iransround
There is a clicking noise when sreering in my Kraton 6s v4 and nothing looks broken
Is it like a constant clicking? That means that the internal gears are stripped. Time for a new one unfortunately. I've experienced this problem before. Sorry. Stock Arrma servos are not that good. But can you steer still or there's no steering at all? Chek the servo saver too (spring underneath the servo). It could be loose. Hopefully it's only that ?.There is a clicking noise when sreering in my Kraton 6s v4 and nothing looks broken
which screw is that I think you might be rightTry the steering plate hex screw? Those can come loose and click... don’t tighten the crap out of it tho... in needs to be snug not tight otherwise the steering will be tight.
The two screw on the red metal plate with the arrma logo that are screened into the bellcrank postsThe stock servo already went I have a savox already and it’s clicking from something in the steering assembly. It might be the steering plate hex screw. Nothing seems to be broken and it doesn’t do it constantly only when I turn the wheel and not every time I turn the wheel. Also I have disconnected the servo and it clicks when I manually turn them too.
