Dmkkings
- Torrington, Wy
- Felony
- Infraction
- Limitless
- Mojave
- Vendetta
Can the same dboot spoke tires that are used on the typhon 6s blx be used on the tlr typhon
Ok thank u
Thank uAs long as it has a 17mm hex, it will work.
Ok but i tried them once before and i think i got the wrong one! Meaning soft or hard! Not sure what to get meaning s7, s4, s5, etc?The GRP 1:8 GTs are a good alternative (cheaper & competition standard)
I've been running them on the local track with a little bashing. The s4 have held up pretty well. S1 wet/soft, s7 hard. Why, what did you think? I found the dhoons average, less grippy than s4, but similar wear, but I'm pretty limited in experience.Ok but i tried them once before and i think i got the wrong one! Meaning soft or hard! Not sure what to get meaning s7, s4, s5, etc?
Not sure all I do is run on the streets! No track near me. The last ones I tried where the grey s7 and they didnt last long! New to the hobbie as well!I've been running them on the local track with a little bashing. The s4 have held up pretty well. S1 wet/soft, s7 hard. Why, what did you think? I found the dhoons average, less grippy than s4, but similar wear, but I'm pretty limited in experience.
If I was sticking to tarmac (rather than loose gravel) I personally wouldn't go back to dhoons. But I'm using a typhon not a drifter....maybe some others with more wider experience might comment, but that's my take
