I've never used green slim but the break clean will dry out rubber and paper gaskets. If you didn't let it sit long and got it back in oil it should be fine.
Ahh thanks. Yes i will be replacing for the comfort of not having to worry and pulling the diff apart again. I knew i shouldnt of sprayed it. Rc life live n kearn lol
I also recommend only wiping the diff gasket to clean with a cloth (as it is just a paper type of material), and would not use any type of cleaner. Was it non-chlorinated brake cleaner you used? If yes, this type leaves no residue or film and dries instantly + it is even used to prep before painting. Otherwards, you should be ok to reuse, as I gathered you just did a quick spray and did not soak in it.
Here's a link to some green slime, but A Main is out of stock. Besides the best stuff to help seal diff o rings, it also works really well on shock o rings also (come in handy when you need to replace a bent shock shaft).
https://www.amainhobbies.com/team-associated-factory-team-green-slime-asc1105/p3068
Thanks mate. Nope i dipped it in so i surely replace it. For the price for a small few bucks i wont have to worry about it in the future or guessing if its broken.
