Current setup on my outcast is max5/800kv with 37/39 gearing, I always run it on punch level 3 and I have already ear plugged my center diff out of the box. Previously on stock setup, there is no issue with it everything runs smooth.
Recently I broke both rear CVD pins (m2c driveshaft) and then followed with blown rear diff. Currently Im rebuilding all 3 diffs and try to make it last.
Already bought the aluminum diff cases for front and rear diff, new diff internal , new RCAWD CVDs with 4mm pin and new set of Duratrax Lockup tire.
The question is, should I maintain the ear plug in the center on my current setup or lower it to 20million since the lockups is heavier than the stock backflips. Will it helps to prevent me blowing another diff if I go down to 20million diff fluid? or should I just maintain the ear plug but lower down the gearing to 34-35/39
Thanks
Thanks
