SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
I use a 2mm ball hex sometimes, depending on the rig, to adjust the Droop from the top. I find the front droop screw is hard to get to due to the upper front arms blocking the driver. I drill a small hole through each upper arm for access to those screws. A hole just large enough the get a hex driver aligned straight down. FWIW.
BTW, I use some Chap Stick on the threads of Droop screws when installing in new uncut threaded arm holes. Those screws must be installed perfecty straight into the arms (done before installing new arms), or the droop screws wont hit the Chassis droop ears evenly left and right. Sometimes I pre-thread using a 4mm cap head socket screw. Droop will be slightly "off", left and right if not threaded straight. The droop screws can drift to the edge of the ears, then chassis ears gouge out faster like this.
