Fallguy
- Felony
- Kraton 6s
- Senton 6s
- Typhon 6s
I've used this transmitter on other firma esc with no problems.
When applying throttle, slow or fast the steer will turn hard by itself either left or right depending on which direction you're turning towars. It will drive in a tight circle. A slight correction and the steering goes completely straight. Does not do it backwards.
AVC is off. No expo. Steering is trimmed. On the bench steering works fine. Any ideas? I finally get this car out and I can't drive it because it just spins out.
Quick update. If I hold the car by the center brace and turn side to side, the steering corrects a lot but in the same direction I am moving the car. So the gyro is on. AVC is off on the transmitter.
