Hi all, did another speed run today. V3 Typhon 6S 29 tooth pinion, 34 tooth spur, spool setup. Stock motor, Max6 ESC. Seems and sounds like to me, that it's cutting power, half way through the run. 95 mph, same as last time when I had the ESC temp set to the lower setting. Raised it to the higher temp setting, and same results. Seems as if I read somewhere about the Max6 cutting power on speed runs???? Now trying to shoe horn a TP Power 4070/2700 in, but will have to use some spacers under the spool mounts, to gain clearance for the rear of the motor and suspension arm. I'm now realizing how valuable the monitoring feature that some Castle motors have would be. More to come.....
