- Notorious
- Talion
- Typhon 6s
I have soldered about a dozen ec5 without ruining one, I have destroyed so many xt90 connectors by melting them.If it feels loose you may want to replace. I personally prefer XT90 connectors. They are easy to solder and stay on pretty well. Maybe it’s just me but soldering the ec5 is a pain getting the bullet to seat back in the connector. ic5 are much better but too expensive for my liking.
+1If it feels loose you may want to replace. I personally prefer XT90 connectors. They are easy to solder and stay on pretty well. Maybe it’s just me but soldering the ec5 is a pain getting the bullet to seat back in the connector. ic5 are much better but too expensive for my liking.
+1 just spread the male tines apart a tad
The EC5 connector on the ESC side has slots in the metal terminals. Put in a hex driver lightly larger than the hole in the center in the terminal and press slightly to expand the terminals. This will make the connectors tight again.
That should work fine to get a snug connection when inserted into the bullet (female) ends. I bet this will work.
I have melted one in the beginning. Need very high temps and a quick soldering (use leaded solder only), few seconds to solder, no more and they won't melt. Use a solder Jig or mount it similar. Preparation is key and takes the longest time. Solder Flow Must always happen fast if done correctly. Adding some additional flux Paste makes for a quick joint also if your iron has lower temps. 750-800 F is best temps( temp regulated irons), using a Large blunt tip. Never use a small pencil tip!!! That works completely against you in all cases. Pretin connector and wires. Cut off any Pretinned wire ends if there, because they are usually Lead-Free tinned at the factory. Lead free always needs a higher temp iron and makes for a slower solder flow. So Lead free and leaded are not compatible. Many make this mistake. Usually when soldering Upgrade ESC's with included factory pre-tinned wires.I have soldered about a dozen ec5 without ruining one, I have destroyed so many xt90 connectors by melting them.
