I tried to reset it but it Only blinks red but thanks for replying, idk the millage but its 1 year old, why shoud i upgrading it?Try a reset to default vaues...
Otherwise she may simply be toast.
How much mileage is there on that OG ESC?
Probably time to upgrade anyway.
Maybe to a 120 Amper ESC this time running 3s packs. A Hobbywing something.
If your esc is toast ,the money your going to spend on a stock esc ,your better off spending a little more for something better ,that will last longer ,I tried to reset it but it Only blinks red but thanks for replying, idk the millage but its 1 year old, why shoud i upgrading it?
I will definitly do that thanks for your helpIf your esc is toast ,the money your going to spend on a stock esc ,your better off spending a little more for something better ,that will last longer ,
Sadly its not in the warranty but thanks for your help and i will definitly purchase a better one.Upgrade meaning get a different better ESC altogether.
>>>Replacing with same makes no sense... Unless you get another for free under Arrma's 2 year warranty. With receipt in hand.
Hobbywing makes decent esc's Or you can go to JennysRC.com and get a replacement one, without any warranty for less $$.
Are you under warranty right now? If so , put in a claim for a free replacement.
Your call. You have options. ESC's simply fail, The Cheap RTR stuff more so IMHO. For no apparent reason or simply from abuse or getting wet etc. No they are not truly WP despite what they say. Take your pick.
Doesn't matter at this point, you need another one now.
Good luck.
