- Ontario, Canada
- Fireteam
- Granite
- Granite Mega
- Infraction
- Mojave EXB
- Nero
- Notorious
- Typhon 3s
I figured this out while rebuilding my Granite. There was play in the ackerman arm. As I had already changed the bearings in the diff I noticed that the screw and flange fit perfectly inside the diffs internal 5x8 bearing.
So I drilled out the arm with a 5/16 step drill and pressed in the old (but still good bearings). Now there's no play and it turns smooth.
Probably won't notice any different while driving since there is play everywhere, but for a free mod I'd rather remove slop wherever possible.
After drilling 5/16 just the depth of the bearings (not through).
After bearing pressed in.
