Could also be a pillow ball coming loose. Best bet here is to take off the wheel and see what is out of place. That'll be a pretty easy search as there is not much going on over there. My guess is the turnbuckle that handles you steering is bent or the end of it is broken.
If it aint broken just adjust the turnbuckle so you get a comfortable angle....or?I searched a lot and can't figure it out, i may try to replace the turnbuckles
Are those longer turnbuckles than the original ones on the kraton? I am having the same issue with my kraton I have almost unscrewed my turnbuckles all the way out on both sides. But I can't seem to get them perfectly aligned, perpendicular to the truck.You've stretched the plastic ball cup in the front buy this ! It a cool spare pack AR330230
I have the same problem and found out that, that washer was loose!
If anyone can help me and tell me what to do I would be very thankful, I think as anyone reading this can tell I’m veryyyy new to this stuff and my stepdad is the one who knows everything but he’s gone atmI have the same problem and found out that, that washer was loose!
