Granite 4x2 17mm hex
Deceased
Austin, Texas
Hello everyone is there a way I can get 17mm hex for my arrma granite 4x2 I want to keep it rear wheel. When I was installing the 17mm hex on my truck I notice the back axles have a different shape axle so I was wondering if there's anything I can do to add those 17mm to the rear ones. The rear have a different shape axle and when I tried to put the axle on it would just pop out there really isn't nothing holding it back from the wheel to fall off
Would I need an adaptor which I don't really want or how can I possible had those 17mm hex. TIA.
For that you would need the typhon stub axles. Typhon 3s stub axle
You will also need a really long hex driver to unscrew the current axles and install the new ones.
This video should help you out!
That what I currently have but I have a rear wheel drive so it doesn't work with the back two axles from the original pic I sent that how it looks like and I cant take that apart I need one of those or should I go with an adaptor?
