bogdaddyd82
- Thread starter
- #21
Hi
I take it that you are talking about the front CVD's. The axle part is way to big to fit. If you take a look at the manual you will see that the inner bearing is big and the outer bearing is small, where as the bearing on the 2wd's is small on the inside and bigger on the out side.
Thank you!
Yeah I guess I will keep searching for a direct replacement solution. I haven't had trouble with the stock dog bones yet. But I know that with more power and the grippy tires I have now. Could cause problems with the stock dog bones.
