Faster as in top speed or faster as in want to get going faster? A gear change is cheap and will make a difference, just be aware that changing gearing is a torque (off the line acceleration) vs top speed compromise.Nite trying to break the bank but just want to go faster..
I'm racing short distance w/22T pinion stock spur.. what's a great gearing?Faster as in top speed or faster as in want to get going faster? A gear change is cheap and will make a difference, just be aware that changing gearing is a torque (off the line acceleration) vs top speed compromise.
Well, the only possible answer is "it depends." First, a disclaimer, I am not an expert on gearing, and I joined this forum to try and find someone with more hands-on experience. That said, here's what I do know: Gears are the cheapest performance upgrade you can make to your Arrma vehicle, so it does not hurt to experiment. The ideal ratio will vary according to your driving style (are you a smooth, momentum driver or an edge of control slide-it-in-the-curves kind of driver?), track (are there long straights were you can take advantage of high top speed, or lots of curves where acceleration is king?), and racing style (i.e. what is the penalty for going off track). The best advice I can give you is talk to other racers and find out what ratios they run with a comparable setup; did they go up or down, and does their style align with yours? Arrma has a gearing chart in the manual, if you can't find yours you can download it from thier website, that can be a starting point, buy a gear and try it out! You will probably find that a different gear works best for one track, and another for a different track, so it doesn't hurt to have a few, just make sure they mate to your pinion gear(also in the Arrma chart). Let us know what you learned, maybe we can help fill in some blanks.I'm racing short distance w/22T pinion stock spur.. what's a great gearing?
