I put a set of grps tires on limitless and the rim contacts the spindle where bearing sits slightly and makes front wheels drag, I put hoons back on and they spin free, anyone run into this before
Yep. Try a hex extender. I use HR 5mm.I put a set of grps tires on limitless and the rim contacts the spindle where bearing sits slightly and makes front wheels drag, I put hoons back on and they spin free, anyone run into this before
Just get some +13mm Extensions, ........Yeap..I am facing this exact same issue. Planning to dremel the GRPs..
I have em on my typhons and OFNA cars. But didnt really like em cause the pin holes are not really accurate, will cause slight binding of the wheel bearings. And the holes get larger over time, causing loads of freeplay.Just get some +13mm Extensions, ........
or truggify it as I did for the other 2 Typhons I own.
My widened Typhons:
