Vendetta Has anyone used a 4S, 57t slipper clutch in a Vendetta?
Dales396lt4
Military Veteran
Columbia SC
  1. Felony
  2. Infraction
  3. Limitless
  4. Kraton 8S
  5. Kraton 6s
  6. Kraton EXB
  7. Kraton 4s
  8. Outcast 8s
  9. Outcast EXB
  10. Vendetta
  11. Voltage
  12. Infraction 4x4
Has anyone used a 4S, 57t slipper clutch in a Vendetta? If so, what pinon did you use.
I guess, I need to go the other way. Looking to put a spool in It. I’m running a complete 4s system 2400 KV 120 amp ESC. Will probably be switching this to a 6S 150 amp ESC. Looking to use a 36t on the spool and maybe 31t on the pinion gear. With my 2.9 horns 6s tires this should be right at 100mph setup. Not looking to break 100 still want to be fast, with out it overheating and I only use 4S batteries because I have 8s /4s Cars just makes things simple.
