Hotwheel85
- Kraton 8S
Hi!
On the 3s forum we discussed k6s vs granite, it was a couple members that had more issues with snapping shafts and pins, well as diff gears when they started to run thicker oil on the K6s.
Is this only when you run heavy oil in front and rear diffs or or is it the same case with going up in numbers on the center diff also?
Still running on the stock 100k in center and i don't like that it’s having more power to the front.
Consider to use f/r diffs with stock oil, and going up between 200-500k in middle.
What is your experience with this?
On K8s it takes everything but that is probably even more solid driveline too?
Thanks for sharing more info about thicker diff oils and stress to the driveline on k6s before i do something about it
