parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
Fam needs help.
I did not mix up the pinion but I am confused as heck and need help?
>> Brand new Losi DB Pro
>> Will run on 3S only
>> Manual says to change the pinion if using 3S
>> Manual says it comes the gearing installed for 2S, 17T
ISSUE:
The tooth that I removed LOOKS SMALLER than the tooth (in the bag) that came optional for the 3S.
Pics
I am confused as heck. I may not understand TEETH but seems to me in the Losi videos I watched the "smaller" tooth is for less heat should be #2, but #1 is smaller. What am I missing here?
UPDATE POST
Looking at CCxRC video..something is wrong in my package
His is 17T and the smaller is 15T...mine does not look anything like these...
15T #s on left
Factory 17T, 2S
>> Will run on 3S only
ISSUE:
Pics
- #1 on the left is the pinion I took off. It is the stock where the manual says is the 17T for 2S and needs to be removed. When I count the teeth is has 14, so its smaller to me.
- #2 on the right is the pinion out the bag that is the 15T but is larger and has more teeth 15, 3S
UPDATE POST
15T #s on left
Factory 17T, 2S
