!Help! RC4GS breaking with MIX
drharney
New Member
I have a 2 wheeled vehicle, so I set Radiolink RC4GS in MIX mode (tank steering).
Problem is, many of the other tweaking functions seemingly don't work.
IE.
1) If I turn on breaking in the "ACCL" mode, it only affects one wheel.
2) If I add a curve to anything, it only affects one wheel.
Does anybody know a way around this?
The RadioLInk docs are a bit lacking in detail or examples and I don't have a lot of experience with mix, but this is what I know.
I used it on my TRX4 to activate the front/rear lockers, my post on RC Talk.
https://www.rctalk.com/forum/thread...nel-mixing-and-what-the-settings-mean.138053/
It seems like the each channel is still active with each button/sw assigned. You can override it activation of each button/sw and for it to work you need to have each channel individually in neutral. i.e. only use one input.
My recommendation is set up each channel without mix. Set you're endpoints, calibration, trim etc. Then put them in a neutral setting and work on the mix from there.
