Are you sure you haven’t just got your FWD/REV trim set too far back on the controller?? raise the car up and check the small adjusters are all set correctly i.e. steering is straight and fwd/rev is fine-tuned so that the trigger correctly operates acceleration and deceleration (reverse)Hey guys just got a new Typhon and having a issue when car is on if i turn off the transmitter it launches in reverse turn transmitter on it stop do i have something setup wrong ?thanks
Everything works now i enable fail safe mode thanks everyoneAre you sure you haven’t just got your FWD/REV trim set too far back on the controller?? raise the car up and check the small adjusters are all set correctly i.e. steering is straight and fwd/rev is fine-tuned so that the trigger correctly operates acceleration and deceleration (reverse)
Bashing in family is the best !Yes waterproof picked it up for $199 cad plus tax at my LHS he will get to bash around this weekend
