Typhon Help with choosing esc for typhon 3s
Otto
Which esc should I choose as a replacment for stock blx 100 esc. Motors that I use SL 3665/3100kv, 3660/3200kv, 3674/3270kv all on 3s. Must support 4s in future. Max 10 sct already I have.
1. Hobbywing QUICRUN WP8BL150 BL ESC. Not sure if esc support 3s?
2. Hobbywing XERUN XR8 SCT 140A ESC.
3. Hobbywing XERUN XR8-Plus 150A 1/8th ESC
Thx
I put the Arrma BLX120 in mine with a 14.8v 4s battery and a 20tooth pinion. It went 62mph stock with the pinion. And tonight it went 73mph on GRP steel belted tires. It's a completely different buggy now. It's insane.
41406
41407
I have the BLX120 and 2400kv combo from a 4S along with a 24T pinion using the HR mount. I have a set of GRP S2 slicks. I just rebuilt my diffs and hope to make a speed run this weekend if weather allows. My PB is 59 but I know it has more. I just ran out of room. I need to find a good place to run.
The quicrun is the same esc as the blx185. I ran the 185 for a while in my granite. It is a large ESC for that platform. If you’re going to run it in the Typhon, you might do some checking to make sure the body will clear.
On 99% I decide for the xr8 plus esc. Thx all for help.
Great esc but the size.... Now i can fit max 68 long motor but Im working on new reciever box and than will be no problem fit 74 mm long motor.
Now enough place for 74 mm long motor.
Mounted 3674 long motor and still is 10 mm gap between esc and motor.
thats great!
Im sure a good 4074 motor will be plenty in the blx 3s but if you ever wanted a 4082, sss make some nice motors at great prices!!!
I run a 4092 motor, fits nice in the 6s.
This is the sss 4092 2140kv motor.
They make 2000kv, 2200kv and 2600kv among others in the 4082 can size
No its 3665 3100kv.
Now 4268 2350kv
Help! What reciever box have you got going on here? I need to change mine to fit a hobbywing 150A and my 4070 motor? It's an arrma 4x4 reciever box obviously but is the granite one different/smaller?
I see!!! You madman. You cut that offer and glued it back together!!
