So I picked up a soldering kit. Never used one before. I have 2 3s batts to power my hot racing fan but the fan came with the single prong deans connector. I picked up some xt30 connectors(because the 850mah 3s had it) and I need to solder on connectors to the fan and also the 1000mah battery to make it all compatible. I also picked up some heat shrink tubing to cover the connection points. What temp am I looking at to use doing this? Do I just heat up the wires from the fan and connector or do I need to add some solder wire to it also? Any guidance would be much appreciated. I'll add pics of what I have.
