SilentSassin
Trying to figure out something but can't find a definitive answer anywhere.
Does anyone know if the sensor adapter cable that hobbywing sells will allow you to run their EZrun sensored motors (3652 SD G3 for example) on a Quicrun series esc (10bl120sd for example).
The description for it only states it's use in the opposite direction (using a Ezrun max series esc with non-EZrun sensored motors), but I realize that there are 2 options to the cable, male or female end, which means that it could either be plugged on the sensor end from the esc or the end from the motor.
Anyone with this experience?
