SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
I have many HS that I purchased lying around They just never fit correctly. Trial and error. I found not using them worked better if I coudnt find a perfect fitting one. The Motor Can IS a Heat Sink. Blowing Fans directly to the motor works great alot of the time. The best fans alone are what makes the difference. Not the HS. But many feel they need a HS to mount the fans, yet never consider how well the HS really fits the motor.I can understand your point, tho heatsinks are made specifcally to transfer heat easier, correct? Hence fans cooling them.
Lol, also not gonna spend more money on a new heatsink when I have extras of these at the time.
Don't get me wrong, a perfect fitting HS is ideal, sometimes efficient enough to not even need fans.
Sometimes I may even use a HS compound/paste on the motor under the HS, used on PC processors HS's to take advantage of better quicker Heat transfer. You truly need a temp gun to experiment with HS setups. Or you are just doing it blind. Wondering why you are still running hot. Pinion changes and all.
