I run dual fans on mine. What battery you have?i have a 3s infartion how do i stop it from over heating and make the battery last longer//
The 6800 should last a good while. I run a 8000mah 3s in mine. Dual fans keep it cooler & run time is about 25 min if I just street bashing, no full pulls, speed runs. How long you gettinga 3s 6800mah and a 3s 5000mah? what dual fans u have?
on the 5kmah less then 10 the 6800mah 15 plusze but whne i run them on my 6s buggy they last alot longerThe 6800 should last a good while. I run a 8000mah 3s in mine. Dual fans keep it cooler & run time is about 25 min if I just street bashing, no full pulls, speed runs. How long you getting
Infartion?? Is that like when you fart but doesn't come outi have a 3s infartion how do i stop it from over heating and make the battery last longer//
Install a smaller pinionhow do i stop it from over heating and make the battery last longer
What makes you think the motor is overheating?i think motor
Ahhh, the coveted Trifartion. You'd think that alone would move enough air to keep things cool but once again reality shows us, things are not always as they seem.i have a 3s infartion how do i stop it from over heating and make the battery last longer//
Only if your body is hermetically sealed and there's zero airflow going on but that's not going to be the case so, no. That would do about the square root of Jack Dookie. It really just sounds like you're over geared. When I got my Infraction I could bash that thing around non-stop for a half hour or 45 minutes on the stock gearing and never have any temp issues. You're either going to need to gear down or introduce fans to help remove heat from the motor/ESC, whichever is causing the problem.will cuting a hole in teh body help at all??????
