Infraction Infraction must do's
Currently reading:
scooby61
Fort mill sc
Just picked up a used not abused infraction for a deal. Any must do's or things to check before running it? Its bone stock.
jondilly1974
Speed running apprentice, motor Slayer 🤘
ArrmaForum Fan
Solutions
1
Toledo, OH
  2. Infraction
  3. Kraton 6s
  4. Kraton EXB
  5. Senton 3s
  6. Typhon 6s
  7. Typhon 3s
Obviously check all screws, bearings, and fluids. I would reset the radio and ESC and go thru the setup so you know what you’re working with.
parcou
ArrmaForum Fan
Memphis, TN
  1. BigRock
  2. Felony
  3. Granite
  4. Infraction
Any setup tips for the dx5?
There are a lot of possible options for the DX5C but for now just bind it and calibrate.... No need to set endpoints for the Infraction really....AVC is an option but you have not said if you like that or not...some do not. Telemetry options if you have specific batteries and some for non-smart batteries... Mine AVC control is the most important for the DX5C
Lost of options once we can get to specific options you want...
scooby61
Fort mill sc
Was having trouble setting up hand brake and avc then i noticed previous owner swapped the avc receiver out it has a sr315 in it. So when i setup avc it takes over aux 1 and then no channel for the handbrake. But no matter since no avc.
parcou
ArrmaForum Fan
Memphis, TN
  1. BigRock
  2. Felony
  3. Granite
  4. Infraction
SR315 does not have AVC ability so did you leave it in or swapped it out? The DX5C I do not use with smart batteries but what I do use I do like knowing the voltage I have left for run time. Outside of that and AVC in addition to use with other RCs is about the most I use the DX5C for..... I do like DX5C once you get over the non-tutorial learning curve...
