It’s so hot 🥵 I almost don’t want to build
Fishtank
work the hardest when no one is watching
Military Veteran
Build Thread Contributor RC Showcase: 6
Arizona
  1. Infraction
  2. Kraton EXB
So the “build season” is here and we have made are picks this year it’s 2 vanquish Phoenix rigs. One kit and one RTR this is my first 1/10 or bigger RTR in along time.
The Falken RTR will be a run around truck with trailer. Below parts list.
ESC- mamba X
Motor- Hobbywing 2700kv pro puller
Servo- Reef Raw 500
Vanquish machined gears
Vanquish rims
Kit will be a dedicated crawler
ESC- Furitek ten 60/100amp
Motor- Furitek 2500kv
Servo reef raw 500
Dig unit with reef 299 Servo
Servo for front wheel overdrive reef 299
Vanquish portal weights all 4 corners
Vanquish light kit
Vanquish wheels “weighted”
I understand, My ac works great, but I do a bunch of stuff in the garage too, it gets to be about 120° to 130° degrees in there once it hits 110° outside. Kinda sucks the life out of you.
My garage gets way to hot also. Luckily I have a hobby room but if I didn't I'd still use my bathroom over the garage.
Don't wand to use the dremel and stuff in the house, metal shavings suck in carpet. :ROFLMAO:
ESC- mamba X
Servo- Reef Raw 500
Vanquish rims
Servo reef raw 500
Vanquish light kit
This brand looks bad ass! Looking forward to the build 👍🏼
You don't have AC?
I keep it 78 degrees 24/7 I tell everyone if that’s not cold enough for ya there’s always outside! 😂 I work in construction (no in the field any more) but I spend a good chunk of my day out there so when I get home it’s time to chill 🥶!!
I keep it 78 degrees 24/7 I tell everyone if that’s not cold enough for ya there’s always outside! 😂 I work in construction (no in the field any more) but I spend a good chunk of my day out there so when I get home it’s time to chill 🥶!! View attachment 311832
Wow! We keep ours at 68! 😁
Funny...I keep mine at 78 also. Plenty cool, especially with ceiling fans.
It’s not that hot here is SWFL but the humidity here adds to the heat index into the triple digits. I feel ya though,went to the park with my kids (minus any RCs this time) glad I didn’t because my kids lasted a while 30 minutes before the melted in pools of sweat 😂. Gonna try again this weekend though. Good luck with the build 🤙
We keep ours at 78 also. The high temps suck but it's those low temps that will kill you because the AC never gets a break.
