Badmofreaker
- Typhon 6s
Oh yeah I forget about that new trendHe must have given it the chop job and shortened it.
You can see the tear drop aluminum weld on the bottom. I wanna race it.He must have given it the chop job and shortened it.
Yes,a few years ago I took a limitless chassis and cut it down and welded back together to make an 1/8 scale, it went 139 on a speed run back thenLooks nice .but is that a limitless? Looks short like a infraction or felony
You got some monster looking lipos there geez.
A limitless shortenedWhat chassis is that?
Made it fit as best I could, body is for the losi s22Sweet. Did you just get lucky with the position of those front body posts or was that planned?
This is what it looked like a few years agoIts been a while but I decided to put my 1/8 scale limitless back together. This time I am setting it up for drag racing. It has an xlx2, hobbywing 1100kv, and running on 6s parallel. Going to get a different motor but I can only fit a certain size, tell me what you think.
Looks like it worked perfect. A bit more wider or narrower and it would have ended up on a curved section.Yes,a few years ago I took a limitless chassis and cut it down and welded back together to make an 1/8 scale, it went 139 on a speed run back then
That is bedazzled brother. Love your ingenuity. How does that center brace mount at the rear? I can make it out I'm gonna make my own center brace for a stretched swb GT but havnt put much thought into how I'm gonna mount the rearIts been a while but I decided to put my 1/8 scale limitless back together. This time I am setting it up for drag racing. It has an xlx2, hobbywing 1100kv, and running on 6s parallel. Going to get a different motor but I can only fit a certain size, tell me what you think.
I haven't tried it yetLove the color and style. Great job man!
Does the wheelie bar actually get used? My car on foams (purple BSR) would never be able to pull a wheelie lol
I actually had a 5660 in it but I cut the wires by mistake and cut past the factory solder,so I threw it outhttps://www.arrmaforum.com/threads/...itless-stock-motor-location.56846/post-836422
This will allow you to fit a 92mm long motor in stock location. You lose 1 bearing in the bellcrank but who cares?
Now you can fit a TP 5660.
The way I make it so it screws right into the top screw holes going down on front and rear diff cases. In the rear I use spacersThat is bedazzled brother. Love your ingenuity. How does that center brace mount at the rear? I can make it out I'm gonna make my own center brace for a stretched swb GT but havnt put much thought into how I'm gonna mount the rear
