Judge my Outcast 8s exb build please
RCSteve
Sacramento, CA
  1. Infraction
  3. Kraton EXB
  4. Outcast 8s
  5. Outcast EXB
I’m about to build my outcast 8s EXB Roller (GO SALES!) and would like to know what people think should go into a proper build. My build is a max5 g2 combo with a 5690 1250kv sensored motor, a JX servo ($44 or so on amazon, cheap and effective), 27tooth pinion, and my radio is a fly sky noble pro. Do people think you need a 113mm motor or does that just make the car heavier.
Going to put two 40mm x 28mm to keep it cool, want to run it one time so the Fluke can tell the temps
I put that combo in the kraton and it’s crazy running 32/20 mod 1.5 gears. Motor got 167 with no fans in high 80s. Just did another run with the fans 157 on motor and it was mid 90s out. I upped the punch to 6 and messed with the timing too. I think that’s a good set up for the O8 IMHO.
Works well in the O8s, I also use those servos for my 4ws axial scx6 too and have zero problems. They are plenty fast and strong at 8.4v and they are cheap.
