At 444oz/in and 0.14 transit speed I would make sure that your steering isn't binding somewhere and that your servo saver is working properly. Some of the servos savers are set too loose from the factory @bicketybam has a video somewhere showing how to take it apart and tighten it up I'll see if I can find it for you.
For some reason I thought it had to come apart thanks for clarifying that. I haven't messed with the new style servo saver and that was the only thing I could remember.Here is what I would do. Turn the truck on and try using the radio to steer back and forth. Watch the two halves of the servo saver. If they separate when you turn, it’s too loose. Add some snap rings to the bottom to stiffen the spring.
It’s not a super simple thing to do. You get the snap ring over the red hex on the bottom side of the servo saver and then use a socket to push the ring between the hex and the saver spring. I think most put two in there for good measure. Should be a permanent fix. ??For some reason I thought it had to come apart thanks for clarifying that. I haven't messed with the new style servo saver and that was the only thing I could remember.
