- Montgomery county PA
- Granite
- Kraton 6s
- Notorious
- Typhon 6s
Okay, i’m having servo issues. Before anyone asks, yes my end points are set correctly, when the servo horn is not connected to a servo it turns back and forth freely and smoothly, my ESC is set at 6V, factory settings. A while back when I built my Kraton I had a Savox 1210 SG and it ran great. One day, 2 months later I landed really bad on the front right tire and it stripped some teeth in the servo so I swapped to an extra servo I had, ds3225, and that one went bad in the same day, not from any bad landings or any crashes Tho... I thought it odd but maybe just a fluke. since then every servo I have put in has stripped out, or burned out, or whatever happens, within minutes of driving it. The last three servos, DS3225, I have not even been jumping, it just driving it up and down a parking lot to try and figure out what is going on. Could my receiver be bad and overloading it? Could my ESC be messed up or something? I literally have no idea what’s going on but this is getting ridiculous, and expensive with all the servos. Spectrum firma 160 amp ESC, aluminum servo mount, hot racing horn, Futaba receiver. Unfortunately it won’t let me post a little video I just took while running but I do have it if anyone needs to see to help me determine what is going on. Thank you in advance
