parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
So I took both front and rear diff's out, they both had 1 shim on the non gear side under the bearing so closest towards the crown gear. So this would be for a looser fit correct? Either way, not happy with the quality, you have to barely tighten the yolk almost leaving it loose for a smooth feeling, if you tighten them up where the case half's touch it is very notchy feeling and only in one spot in rotation, it's like something is out of round so to speak but can't see it. I have had only one run on this totally stock and on 2s no bashing, due to weather out here. Bearings are good and internals on the diff look good to with the planetary gears. I noticed on You Tube a lot of people shredding the diff gears on there Big Rocks also and getting the metal set posted above. I ordered the HR yolk and both metal diff and pinion, spendy but hope it resolves this issue. It's a great truck other wise I like it. I'm new to RC cars, been flying heli's for the past 8 years and needed a change, fitment with heli's is crucial specially in the drivetrain, so this is dissapointing, at least I cant crash it and cost me hundreds of dollars to repair and parts flying off in a 30 foot radius! Sorry Goofy, I'm not trying to Hijack your thread, you just had the perfect post, I was going to post the same topic and see you beat me to it.
Been there. With the plastic yoke, it is a balancing act. You do not want it loose, but you need to get it tight since the diff is under a lot of force and flex close in to play on the plastic yoke. Yes, there is a catchy spot so I get it as tight as I can where it is not so bad, but the yoke is not loose....then you add lube to the diff house it will help in that regard and be well. Many, including me have found great success with just the HR metal yoke alone with the other stock parts of the diff. For the metal yoke, you loctite the screws and tighten it down once you test and have the right shims in place for the gear mesh.
This is only for the rear since this is where the power module is located. No issues at all with all stock on the front.
