KRATON 12S BUILD
rcmodcrazy
What do y’all see 😈🤘🏻
Anything done to the kraton? Like aluminum bulkheads and whatnot? That combo will destroy anything with plastic drive train stuff.... Mike
Aluminum diff case front/back
Vitavon diff cups front/back
Aluminum suspension mount ABCD
aluminum steering bell crank
Double backflip standing - well someone had to have that idea.... :unsure:
I pushed the 9500mah 6s lipo as far forward as I can hoping to keep the front end grounded 😂😅 bout 12+ lbs of electronics
Just received the vitavon extended motor mount in order to give the 70x120 motor some more surface area for the front bell cover. Also purchases an aluminum motor mount slide so that instead of just 2 screws holding the motor it would be 4 screws bolting the motor the the slide.
back flip ready 😈
Depending on what kind of surfaces you drive on and driving style....you probably will want to invest in upgraded CVDs and dogbones if you haven't already. 12s is alot for even an upgraded arrma 8s truck...hell, 12s in an 80lb raminator is wild...Then again, you could get lucky and not have any issues. But if what I know from experience, you might be changing out outdrives as often as top fuel cars get their valve springs changed.
So I finished the build about 3 weeks ago, so far so good. It’s an absolute beast!!!!
86mph easy no sweat
I can defiantly bash in the 60+ mph and runs cool 😎
Upgraded diff
Aluminum diff case
Vitavon gears
Vitavon axles
Vitavon diff cups
Vitavon front drive shaft
560kv 70125 motor 12s
MAX4
Proline mx43s
Had to relocate the motor and batteries as well as center diff. Vehicles weight is still preety even from left to right about 500grams off and rear to front isn’t too bad either
