Harlon
- Kraton 6s
https://www.amainhobbies.com/lunsford-tekno-eb410-machined-shock-bushings-6-lns7331/p722973. This is what u use with the shock rod ends i suggested
Buy the excact ones I linked for youoh yeah. Do I need to buy flanged pivot balls?
nice, would those also work with these: https://www.amainhobbies.com/tekno-...ock-rod-end-spring-perch-set-tkr6140c/p979926https://www.amainhobbies.com/lunsford-tekno-eb410-machined-shock-bushings-6-lns7331/p722973. This is what u use with the shock rod ends i suggested
I hadn't seen it yet my badBuy the excact ones I linked for you
What pivot balls do you recommend using with the Arrma Nero HD's ?I prefer the RPM bumper. I’ve been running it for 2 years without issue and I had beat on the poor thing. Shock rod ends have been fine for me, but I have a few of the Arrma Nero HD ones installed. Definitely get metal chassis braces.
What size pivot balls for the kraton 6s and Notorious 6s???Here is a good shock rod end upgrade. And you get alot in a package. https://www.amainhobbies.com/rpm-sh...9gGfl4OghTL0KBfueSqGNdAI6rEmFShhoCImIQAvD_BwE
Make sure to get a pack of pivate balls as well.
I used the Lunsford ones.What pivot balls do you recommend using with the Arrma Nero HD's ?
Thanks.. these are what come stock on the car right? If I broke something that is stock as easily as I did I would rather order an upgrade while I'm at it.https://www.horizonhobby.com/shock-rod-end-set-hd-arac8969
Are your shock rod ends and perches
https://www.amainhobbies.com/lunsfo...4SSE9Pam5fYw8FDVCPlsXrsTgNQVwaWkwjb3RkOW9yHrF
Are the pivot balls. They all fit the 6s line no problem.
No those are upgraded parts.Thanks.. these are what come stock on the car right? If I broke something that is stock as easily as I did I would rather order an upgrade while I'm at it.
Left is stock size right is the ones you want.Ok just so we are clear. The small one is stock. The big one is nero HD with lunsford titanium pivot balls.
