Purchase List
- Arrma
- 1/5 KRATON 4WD EXtreme Bash Roller, Black
- 30T Mod1 Safe-D8 Pinion Gear
- Lower Suspension Hanger, Rear Front, CNC Aluminum
- Lower Suspension Hanger, Front Rear, CNC Aluminum
- Servo Saver Axle, CNC Aluminum
- Steering Set, CNC Aluminum
- Wheelie Bar
- Shock Collar, CNC Aluminum
- Metal Diff Case Set F&R
- Diff Gaskets
- Sway Bar 4.0mm
- Sway Bar 5.0mm
- HD Threaded Hinge Pin
- Castle Creations
- Mamba XLX 2 1/5 & 1100Kv Motor Combo with 20A BEC
- 6.5mm Polarized Bullet Connectors
- B-LINK Bluetooth Adapter
- Telemetry Link X-Bus
- Castle Creations 20 Series Dual Fan Shroud w/ Fans(upgraded to Reedy HV 40mm Aluminum Motor Fans)
- Spektrum
- DX5 Pro 2021 5-Channel DSMR Transmitter
- 7.4V 2000mAh 2S Li-Ion Transmitter Battery
- SR6100AT DSMR 6-Channel AVC Telemetry Surface Receiver
- S2200 G2 AC 2x200W Smart Charger
- S9120BL 1/5 Digital HV High Torque Brushless Metal Gear Surface Servo
- Gęñš Åçë
- 14.8V Bashing 11000mAh 4S 100C LiPo: EC5
- Hot Racing
- Triple Bearing Support Rear Hubs
- Triple Bearing Support Front Hubs
- Bleeder Shock Caps
- Dirt Shield Wheel Nut
- Upper Steering Brace
- M2C
- Xlx2 Ecs Mounting Plate
- Stiffener Bar Brace Ends
- Front/Rear Hinge Pins
- Cvd Outdrives
- PPS
- Swith Mount For Xlx2
- Scorched Parts
- Titanium Center Driveshafts
- Pro-line
- Trencher 4.3 Pro-Loc Impulse Wheels
