Kraton Kraton front shock oil
Skinso
Northern Ireland
  1. Kraton 4s
  2. Outcast 6s
I'm about to replace the front bent shock rod, what would be a good oil weight for the front. thanks
i would go 70 or 80.....especially if you have stock springs and running heavy batteries....or it will scratch the underside on the ground when you break...
Chassis slap, without it, your going to break the shock towers off the diff case. It's a good thing
