redman16
- Points
- 48
Hi I have a kraton 6s exb I am trying to gear and set up . So far I have a max6 esc with a toro x8 pro 2100kv motor and my gears are 42 spur with a 20 pinion and a center spool no center diff. I have tried to run this set up with a 3s battery it has great power Maby too much but it seems to cog a lot and heat up quick after about 10min. Do I need to go up in my cell count to run like this or change my gearing. I would like to use 4s but have many 3s at the moment. Do I need to go up to 6s . The tires I have on are badlands in the front and trenchers in the rear is that ok or dangerous for the diff.I am wondering if I should try to fix the issue with 3s power or go up to 4s first then fix the issue?? Maby with 4s there is no problem.
Will I need different gearing for 3s vs 4s vs 6s??
