TheStapler
I have found a model for a 3d print center shaft for kraton and outcast 4s. Has anyone tried a 3d printed shaft?
Only reason i was interested in 3d printed because I've only driven my kraton 3 times off road and already need a new shaft due to rocks getting stuck between motor and shaft.Not worth my time and filament. No issues with the OEM unit so no benefits.
What you need to print is a cover. https://www.etsy.com/listing/1130230560/arrma-3s-blx-center-driveshaft-cover-lwb
My Vendetta shaft is starting to get a bit abused. Im at work so I can't measure. Is this the same length as the Vendetta? I mean if not I'll just extend it and print it. Just curious.
I gotcha, Thx.The Kraton 4S V2 center driveshaft is a tad longer than the standard LWB shaft.
