Kraton Kraton v3
There are hobbystar, hobbywing, a few others for options. If you go castle, you would have to change the motor connections to the esc from 6.5mm to 5mm. I think blx is 5mm. ..
I thought it was 4mm.
The BLX185 esc is a rebranded Hobbywing Quickrun 8BL150, the specs for the 8BL150 are listed as 4274-size or smaller motor with the KV<2400.
I do like the stock setup!!! It is potent like u said!!! Just curious to know what other options u can go with! Thanks
Cool thanks for the reply!! I like the stock setup, just curious on what other options are there!!
