Fireteam Max6 G2 or Max5 V3?
stevenwm
Central Valley Ca
  1. BigRock 4x4
  3. Mojave
  4. Senton 3s
  5. Typhon 3s
  6. Vorteks
I’m not that smart 😁
I’m looking for a esc for a 5th
Was wondering if I should go with Max5 v3 or Max6 G2
I noticed they’re both 200amps but Max6 has the thermal protection
Probably going to pair with a Spektrum 780kv
TIA
To clarify, this question is for 1/5 scale? You posted it under Fireteam in the 6S section.
The Max5 V3 will do a much better job dissipating heat than the smaller Max6 G2. The Max5 is way bigger.
The number in the ESC name conveys the vehicle scale it was designed to power.
Thank you!
Yeah im looking to upgrade my esc in one of my 5th scales.. probably should have put this in 8s thread
The fact that you're putting it in a 1/5 truck eliminates every system that's smaller.
Either option will be better than a Firma 160 that motor was designed to be paired with. Depends on usage/application/gearing and how much flexibility you require in programming/logging.
