My Kraton is doing something weird. Most times it'll power on normally, but when I turn right the ESC will power off, leaving only the fans running at about half speed. Release the steering and it will go through the startup sequence. Throttle does not seem to affect it as it moves forward and backward.
Also, if I just physically turn the wheels (not the controller) it will do the same low power/esc shut off thing.
There are also times that it won't even start up, just go right into the fans only mode. I'll shut it off, restart, and it may or may not go into full power mode.
Should note, I added the Yeah Racing fans to the motor, but they worked well for a month and a half.
I would appreciate any thoughts as I'm at a loss. I bought the truck maybe two to three months ago, so it should still be under warranty.
I can post a video of needed.
