I ment 4s hahaha I don't have any 3sSure it could be fun on 4S. Or you could run a couple of your 3S batteries in series for 6S.
Check out the iPhone app called “gear speed” for possible gearing calculations. Or go to this site:
https://scriptasylum.com/rc_speed/top_speed.html
If ya tell me how tall your tires are ill give ya some accurate gearing...I've had big 56mm low kv motors on 4s an it's the way to go...your adding weight with system ,but losing weight in packs....the tp big cans a 6 pole motors an have tons of torque an low rpms don't stress electronics....4s power geared correctly can be very fast an handle better cause less weight..weight adds crappy handling an more damage on crashs...plus more drivetrain abuse an stress all togetherI ment 4s hahaha I don't have any 3s
I'd guess tires are 6.8in tall if so something like this on 4s will get ya 55-60mph...gotta now ttc of your motor mount..30tp+ 40ts=70 ttc. (Total Tooth Count)most 25×25 motor plates are like 60-85ttc..gotta stay in between there for gears to fit..If ya tell me how tall your tires are ill give ya some accurate gearing...I've had big 56mm low kv motors on 4s an it's the way to go...your adding weight with system ,but losing weight in packs....the tp big cans a 6 pole motors an have tons of torque an low rpms don't stress electronics....4s power geared correctly can be very fast an handle better cause less weight..weight adds crappy handling an more damage on crashs...plus more drivetrain abuse an stress all together
You definitely need to run 6s with that motor. Running 4s on a 6s rig is like using half your D#$& for F%$#ing.I ment 4s hahaha I don't have any 3s
You definitely need to run 6s with that motor. Running 4s on a 6s rig is like using half your D#$& for F%$#ing.! Yo can use a 4s and 2s to get 6s too
Hey now..
What are you implying!
I use 3S with my 6S Kraton..
It still gets the job done.
When people say they have tried everything off road an alot on road everyone including myself thinks there full of bsI'm not disagreeing with what @K-BASH is saying. If he's done it successfully, I believe it's likely a good option.
The Firma 4985 1250kv is kind of an in between sized motor..between 1/8 and 1/5 scale. So not really working that hard in a 1/8 rig but a bit over worked in a 1/5 scale. I know, Arrma's 8s are really a 1/6 scale. But, basically, the 6s Arrma's are half the weight of the 8s models out of the box. Which also explains why Arrma 8s rigs are typically underwhelming in stock form.. too much heft for the 4985 motor, some even feel the 5687 is too slow.
In a 6s rig, that 4985 is plenty, perhaps too much. Depends on what one likes. So, 4985 on 4s? Gotta believe what K-Bash is saying, can fill the bill.
That's the best part of this hobby is trying different shiot...I'm all for trying new setups/combos!! Even more enthusiastic for reusing what's on hand. Give er a go!! How else would we have ever come up with Lemonade?![]()
I feal I'm a lil overpaced..everyone used to think I had like 10+ rcz..only had like 4,5 I just completely changed them all the time..lolHey Some folks are just a tad
paced..
But we can still![]()
