Steve B in Vegas
+11mm Kyosho Hubs on the Mojave.
Slowly evolving the Axial Ryft into a crawler.
Awesome photo as usual @Steve B in Vegas . Keep them coming. I've heard the Ryft is not a good rock crawler, more of a basher. Looks like that's not true. What's your thoughts?
Well, it's not my first choice by a wide margin, but with a bit of fooling around, it will pull lines that would surprise you. We are working on a piece for the website called The Tale of Two Ryfts. One built as a rock racer, the other a rock crawler. Both are progressing well towards their goals, but the rock crawler is really starting to shine.Awesome photo as usual @Steve B in Vegas . Keep them coming. I've heard the Ryft is not a good rock crawler, more of a basher. Looks like that's not true. What's your thoughts?
Beautiful scenery. Unreal to me.View attachment 360502
We about have the first phase dialed in for the Ryft Rock Crawler project. It knocked off some bonkers of lines today.
That looks sharp. The Traxxas Canyon Trail tires scored very high in our evaluations, and we happen to be quite fond of our TRX-4 2021 Bronco. Traxxas are highly capable crawlers.My only trail rig. Stock configuration, but loaded with upgrades. Aluminum transmission case, all hardened gears inside it and in the diffs. Cheap AMK brass that had to be dremeled to get bearings to seat. Treal diff housings, Sinecam servo, slightly larger Injora 7.4v aluminum case shift servos, Holmes Hobbies puller pro standard length with Castle Mamba Monster X. Shown it in various threads here. Only a trail rig. Nothing to sneeze at.
View attachment 360516View attachment 360517View attachment 360518
It looks real.My only trail rig. Stock configuration, but loaded with upgrades. Aluminum transmission case, all hardened gears inside it and in the diffs. Cheap AMK brass that had to be dremeled to get bearings to seat. Treal diff housings, Sinecam servo, slightly larger Injora 7.4v aluminum case shift servos, Holmes Hobbies puller pro standard length with Castle Mamba Monster X. Shown it in various threads here. Only a trail rig. Nothing to sneeze at.
Don't even have a functioning crawler yet, but I've started accumulating materials to build a backyard crawler course. Everything pictured here was acquired for free. Not pictured are 3 more pallets that I have yet to break down.
It seems like half the fun of this part of the hobby will be designing/building the course itself! I have a couple buddies with 1/10 crawlers as well, so hopefully we can get in some good backyard sessions.
Built a little articulation/sidehill obstacle thing. Set the TRX-4 high centered over the tallest peak just to double check the overall scale. New driveshafts, bolts, and wheels/tires arrive tmrw, so I should be able to get this one up and running tmrw evening!
Looks like someone is in for a good time.
