- Thread starter
- #61
I wouldn't upgrade the servo unless you keep stripping gears out on the original. The savox is good but when you are bashing these rigs the front wheels are of the ground more than they are on ha ha !!The savox work better than the stock ??
Been thinking of the upgrade.
My servos a slug if the cars not moving... But no real problems with it when its on the move so not sure if its worth changing ?
Took the kraton and typhon back down the new spot today with my mate. Cracked my centre diff gear again in the typhon !! Im guessing just jumping too high for a low car or something ? This is why a Need an Outcast :-D Kraton went awesome ! Servo held up good but on the last battery packs a small click started in the front diff so i gather i lost a tooth somewhere in there. 2.5 hours of bashing tho so got to expect something to break
I just spray inox on the bearings after cleaning them with the electrical spray... Ive only had one bearing fail in 6 months so it must work ok... I have been meaning to get some proper bearing oil tho... Want to take them all out and give them a kero bath and good oil
I've never broken a Planetary gear but heard of people breaking them. Would it be chassis flex pushing the dogbone in to the diff ??
2.5 hours is a fair session do you cool the rig between packs ?
