green98tj
- Falls Church, VA
- Felony
- Limitless
- Kraton 8S
- Kraton 6s
- Typhon 6s
- Typhon 3s
- Vorteks
I have limitless with a Castle 1717 motor, XLX2 ESC, corvette CR7 body, stock 34 tooth spur. I've tried a few pinion gears but I'm not getting the speed that I want. Didn't even break 100mph. Most recently I used a 34 tooth pinion. The logs say no temp issues. However, I only got 47k rpm and 67% power out. Seems obvious to go to a smaller pinion based on the logs but with that motor/esc combo I would not think I would have to. Any advice? logs attached. the last run had 34 tooth. before that it was 27 tooth. Thank you!
