LunchBox
I also charge outside the house not inside so maybe the embers of the shed! Tho still not good
@Dustin Mustangs Should I try to charge it ot maybe call it a lost cause......honestly I didn't notice it till after the charger was done charging. The cells check good just low and there is no visible swelling?Having a lipo at 3.1v per cell will surely damage it, yikes!!!
How will the performance change... won't last as long or lose of powerYes, charge it as soon as you can. It should still work, just not with the same performance.
Ok.... it a venom 5000 mah 25c 2s I ha E it on a 2amp charge now I'll let you know how it goes....now to figure out why I lost connection between my radio and truck last night.... thnx for the help @Dustin MustangsPossibly both but most likely loss of power. You tell us once you get a chance to try it. Be cautious the first couple of charges. Low rate, watch closely, and see how well it is balanced when it is done. If all goes well the first couple of times than just let her rip like normal.
Ok I charged it up. Took the charge fine cells are even.... now I have to get my other truck to see if the performance has changed any!Yes, charge it as soon as you can. It should still work, just not with the same performance.
The battery is working fine.... I think I'll run it in my granite mega and not the blx....but it seem to be working and holding charge fine!Possibly both but most likely loss of power. You tell us once you get a chance to try it. Be cautious the first couple of charges. Low rate, watch closely, and see how well it is balanced when it is done. If all goes well the first couple of times than just let her rip like normal.
