Lipo dangers
RcRookie
  2. Typhon 3s
So I've been doing some research on lipo safety and I invested in A lipo bag. Also I never leave the charger unattended unless I'm in the house usually I'm in the same room and I always unplug it as soon as it is fully charged. Other than impacts and obvious issues what else may cause a lipo to combust? Let's say I Leave them at home for vacation on storage 3.8 V what are other potential dangers while stored? Thanks
Most of us keep them in the LiPo bags and also inside a metal toolbox/ammo can etc.
Another consideration is heat. In the summer you would not want to keep them in the garage.
LiPos like cold or room temp. I keep mine in the mud room near the garage, but indoors. Being in a metal tool box and inside a LiPo Bag I feel ok about it being indoors, but it is not kept near any bedrooms!
You would also want to visually inspect them. Over time they could begin to swell. At some un-defined swell size/amount you want to fully discharge the LiPo and dispose of the battery. Take special care of the wiring when in the RC to be sure wires do not get frayed or damaged.
Your reading into things a little to heavy imo... there are always tell tale signs when a battery is going to do something crazy... they will puff up.. sitting stagnant on a shelf at storage charge they cant do anything crazy... if that was the case they wouldnt sell them.. they must be damaged, wether smashed, under or over charged, ruptured or physically shorted to burn..
No you shouldnt leave them unattended while charging.. but you don't have to physically hover over them.. most lipo fires are due to the above damage and charged anyway... basically user error.. there are instances of them burning in rigs, but it's one of two things, user error, or an under powered battery for the amp draw...
Just for reference, you most likely hold a lipo in your hand and to your ear every day..(cell phone).. no need to be scared...
Thanks that is really good information!
Cell phones use Li-ion batteries. This is because lipos are too dangerous to hold against your ear. Just saying.. lipos are still very safe when treated well tho.
That's what I hear, that as long as you dint puncture,overcharge. Or overheat them they are safe?
You sure?? Thought lithium ion was hard cell packs
I’m pretty sure. Not gonna act like I’m mister battery expert here, but I’m fairly confident that they’re li-ion
Edit just hit the googler. Here’s the iPhone:
They actually use both... beleive it or not as of 2018 the lithium poly battery is the choice over the lithium ion.. but it depends on the manufacturer..
How can I see if my hard case battery's swell? :)
Or are going bad
Usually as whole the hard cases will show swelling in the center under the decals.. I'm pretty sure they specifically leave that section of the case thin for this reason...
This is a swelled hard case.. you can physically see the buldge.. I also pulled back the decal to show the thin cutout
They also use lipo batteries in those jump boxes and people keep those in their trunk.
Also do note that any battery over 2s 2200mah will burn through a lipo bag, best bet is a vented ammo can.
Thanks ,this is very comforting actually. I figured it as much but sometimes a little reassurance is nice especially since I'm a newbie ??
Or are going bad
This is an SMC hard case. On these they begin to crack/ split in the middle near visible where the #1 is written on it. This is G10 which is basically type of fiberglass. Others I have had made of plastic the 2 halves of the "shell" will split.
This SMC true spec extreme has been this way for over a year and is completely fine.
I had another that had to be drained and trashed. Hurts to throw away a Lipo that cost over $100.
