- 4x4-Mega
- Granite
- Infraction
- Kraton 6s
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Typhon 3s
Bummer.
Anyway to make it work?
What about the RPM bumper?
I have the tbone front bumperRear or front? I used the rear one on mine and the RPM front one on the front.
Says in their description m2c chassis is for stock bumper.Whats the issue? Lots of guys use that combo.
I remember when I got my M2C, it came with a plastic spacer to put between the chassis and bumper. The M2C has a lip between the first and second set of holes on the front. Even if your T-Bone didn't come with one, you could easily fab one out of plastic the same thickness as the lip, drill two holes in it, and your done. That would be the only thing holding you back I think.I have the tbone front bumper
Yep, it's molded in the RPM front bumper. Also if you buy ARA330230 the Arrma composite rod end set it comes with the original front bumper. I had tried to cut down, and keep my original Outcast bumper, but when I broke a Front upper hinge brace, when taking it apart I noticed I had also torn the holes of the bumper that key into the chassis. The short Typhon bumper gives a much cleaner look imo.I run T-bone front bumper and RPM rear skid, the problem I found with the T-bone was that ideally you need to fit conical washer/spacer under the bumper to stop it from ripping the screws though the bottom.. the RPM skid has the conical part moulded into it, I assume the front RPM bumper is the same..? I don't have the bumper so can't say, maybe someone on here can confirm..??
Oh, and you still need to fit the small plastic spacer that came with the chassis too..??
View attachment 49328View attachment 49329
