hello there,
does any one know if the M2C rear Hinged Pins kit will fit the 6s Senton?..
TIA
TIA
With the 6s senton the rear bumper has a plastic cover that covers the rear hinge pin block so it may not work. You might be able to fasten the lock nut on over the outside of the plastic but it's beveled to hold the countersunk screw if i remember right.All the 6s M2C hinge pins/ mounts will fit a 6S Senton.
m8, as im not a native English speaker i kinda lost u..^^^
Then using the Arrma EXB alloy hinge pin mounts along along with the plain plug and play M2C hingepins is the better choice perhaps.
IMHO, you don't even need the M2C nut captured mounts at all. We are talking the 6s Senton with Short Arms anyway.
$M2C$ nut captured mounts/pins being overkill.
EXB alloy mounts or even HR ones are just fine.
