- Granite
- Kraton 6s
- Vorteks
I figured I should start a build thread for my son's Granite. It started as an unremarkable Mega V2, but it's now getting more interesting now that it is in "sleeper mode" with the 3S V3 guts...and I have a couple of things coming this winter, so I'll update as I move along with the modifications.
So, as it sits currently, it is a Mega V2 with rubber sealed bearings all-around and upgraded with the following parts from the 3S V3
- diffs + input gears
- Power module (slipper assembly + adjustable motor mount)
- ESC + motor
- Receiver box and Rx
- Spektrum SLT3 Tx
- Spektrum S651 servo + stock servo saver
- Front turnbuckle links
- Wheelie bar
I have the rest the the Granite 3S V3 as spare parts. I also have the ADS-15 servo from my Kraton V4 and a Kimbrough 124 servo saver ready and waiting for the 3S V3 Spektrum servo to fail.
A very cheap, but effective upgrade I did also was to solve the leaky shocks problem by replacing one of the o-rings in the shocks o-ring stack by a nitrile o-ring (2.6mm ID; 7mm OD, 2.2mm W). They did not lose a single drop of fluid in 5-6 months following this upgrade. I tried replacing the 2 o-rings, but it makes the stack too thick and I couldn't snap the plastic cap thingy into place. I guess one could use 2 of these thicker o-rings by shortening a little bit the plastic spacer between the 2 o-rings.
- ESC + motor
- Spektrum SLT3 Tx
- Wheelie bar
